Old 06-30-2015, 10:53 AM
Mr Jody Mr Jody is offline
Default Pump Rotation Direction
Verify that the flow/rotation direction for the new pump are the same as the original. If the pump was designed for a serpentine system, it will rotate in the opposite direction to provide flow. I was talking with someone at a car show who had installed a crate motor that came without the pump, and he indeed had installed the wrong pump and had overheating problems. After talking with the supplier, he installed the correct pump and the problem went away.
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
