Old 07-06-2015, 07:23 PM
Rebel1 Rebel1 is offline
Originally Posted by Towmaster View Post
Commodores all run the regulator in the fuel tank...... Mine is in the boot, only one -8AN line runs to the engine, good for 500+ rear wheel. It is, however, not in the wheel arch.
Yep, If you use the corvette filter regulator then most use the ford MPA in the tank. Much easier to fit and will accept the Walbro 255Ltr pump.
