Old 07-09-2015, 07:36 AM
blue sky blue sky is offline
Originally Posted by MAStuart View Post
AJ What did you come up with dimensions? Keep in mind the Dimension I am giving are for a coupe. This should not change things because they are based on a leaf sprung car. No my drawings the pick up points for the front control arms are 24 1/4 inches apart and the spring eyes are 38 inches apart when the spring is compressed flat.
With all the different numbers for different cars i get a headache trying to figure what is right.
Mark
Mark, Quite awhile back I was given the dimension of 24 1/8" by an owner from his original car. I did not physical take this measurement myself. There is another person I want to ask on this and hopefully over the weekend I would like to pop down to a shop where some Mk2 cars should be. I am not knowledgable with the coupes so I could not provide reliable information. I thought the base of the chassis was still fabricated by AC Cars which most likely would have been the same with suspension pick up points. The motor mount towers were lower in height than the roadsters (this is based on the drawings and reproduction Daytona's I have seen being made).
