Old 07-09-2015, 09:35 PM
dubaicobra dubaicobra is offline
Send a message via Skype™ to dubaicobra
Originally Posted by cycleguy55 View Post
Hoosier has the following DOT rated tires:
a) Sports Car D.O.T. – Bias;
b) Sports Car D.O.T. – Radial;
c) Sports Car D.O.T. – Radial Wet; and
d) Pro Street D.O.T. – Radial.
Most of these are 'H' speed rated, but the Sports Car D.O.T. – Radial is 'W' speed rated. With the exception of the Pro Street D.O.T. – Radial they're all metric sizing so you'd need to crawl through specifications and dimensions to see which would be comparable. OTOH, a query to Hoosier's tech folks at info@hoosiertire.com could probably get you a quick answer.
If you're not committed to staying with Hoosier you could contact Tire Rack (https://www.tirerack.com/content/tir...r_support.html) or any other large tire distributor / dealer.
Brian thanks so much for your help , I will follow your recommendations and write them, very informational respond
thanks
