Old 07-12-2015, 11:29 AM
car4jim's Avatar
car4jim car4jim is offline
Cobra Make, Engine: Kirkham, 427 side oiler
I can't speak for your carb system, for my 4bbl Robert Pond setup, they required PCV and hose from valve cover to air cleaner. They basically inspected the block for casting number and determined it was a 1965 ford (it isn't) and applied 1965 smog rules to the engine. No big deal, put PCV and you should be OK. The first time I went, the tech was kind of an a-hole. Second tech when I returned was much more easy going. Kind of silly given its a smog exemption. Play to the rules...
