Old 07-12-2015, 07:30 PM
mickmate's Avatar
mickmate mickmate is offline
It is a balance bar set up that adjusts how much front/rear braking you're getting. The threaded rod through the middle should be through a spherical bearing inside there. It looks like it is adjusted out too far with excessive sideways play and no shim washers in there. Nice Wilwood instructions on setting them up here http://www.wilwood.com/PDF/DataSheets/ds252.pdf
mickmate
http://www.actoncustom.com/
