Old 07-13-2015, 05:27 PM
avdcav avdcav is offline
Cobra Make, Engine: Everett Morrison
I just finished the exact swap , first dive was this weekend it was magical
Compared to the c6. 4k into it all and about 30hours . Taking the qt bellhousing off
50 times to trim was the only real pain in the ass.
I also have a mini ht starter had to shim with 2 plain washers to clear fw but worked perfect
Forte master slave combo I modified the bracket , it just didn't line up dead center on the slave to fork. But it works great
Ram clutch
McLeod flywheel
Tko600
QT bellhousing
New drive shaft 2" longer 14.5 instead of 12.5
Jordon shifter. this thing is just awesome
Pedal cluster I just made from 2 jegs clusters 6.250 ratio
Have at it. You'll be glad you did don't pay much attention to
The shifting horror stories try and old Porsche or Ferrari and you'll
Really see what sloppy bad shifting means, 600s are just notchy if you
Pre gate it in 3rd first it slides into first like butter.
