Thread: Mark III Build
Old 07-19-2015, 01:16 PM
cycleguy55's Avatar
Originally Posted by Detroit Bill View Post
I do want to mount a fire extinguisher on the back bulkhead between the seats.
I have not worked with a lot of fiberglass. Should I just use a sheet metal screw or should I through bolt?
I've toyed with the idea of 'molly' type expandable anchors (http://www.grainger.com/product/WESTWARD-Hollow-Wall-Anchor-WP57878/_/N-/Ntt-molly+anchors?nls=1&nlsIt=0.8&ssf=2&sst=subset&sug gestConfigId=6&s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/11K355_AS01?$smthumb$) or 'blind jack nuts' (STAINLESS STEEL BLIND JACK NUTS / IMPERIAL RIVETS & FASTENERS CO., INC.), but haven't tried them due to the possibility of creating stress cracks in the fiberglass.
I have a tool to set Rivnuts or blind nuts, but have never used it in fiberglass, as I believe it would stress fiberglass even more than would molly anchors. I found an old dune buggy thread where they debate the issue, and it seems their consensus is similar to mine: bolting things to fiberglass
Any of the above would probably work if you used a metallic backing plate behind the fiberglass, but if you're going to do that it may be just as easy (or easier) to through-bolt it.
Given the weight of a fire extinguisher and the G-forces it will be exposed to, I'd be inclined to through-bolt it. I through-bolted the electric fuel pump in my trunk, and it weighs a lot less than a fire extinguisher.
On another note, sounds like the first drive(s) have fulfilled your expectations - at least so far. Enjoy.
Good to hear your wife enjoys it - mine says she enjoys it far more than she thought she would. Then again, she's one of those people that jumped out of a perfectly good aircraft - for fun.
Brian
