Old 07-19-2015, 03:38 PM
Gregwindsor Gregwindsor is offline
Registered User
Thanx for the responses guys!
Real1......Its a fairly new battery....will substitute for a new one and see what happens...I know it will crank till the cows come home when I had the MDS issues, but I will try a new one anyways
Avdcav......don't hava load tester but did put a multi-meter across the battery whilst it was running. Showed lotsa charging voltage and the voltage was surging with the ammeter.
Steve-O....will check into SCOF. I had read somewhere that there was a wiring change but couldn't find it on Google. Ya, I see the harness for the driver's side alternator mount. Don't want to cut it off if I don't need to. Will try a battery first and check out the wiring change on SCOF. Its weird that this started happening after the MDS box up-grade. I know it will jump a spark at least and inch and thought somehow it was interfering with the electronic regulator but because there is a bulletin on this issue..it might be the problem.
Thanx Again
Greg
