Be aware of one down side; with most non-EFI engines adding an electric pump has a risk of hydro-locking the engine if the float gets stuck on the carb. I have seen this twice. The condition is this: the engine is not running, the key is on and the pump is running, the float is stuck so the pump is dumping fuel into one or more cylinders. This is going on but the owner does not know it because these add-on pumps do not shut off. The driver then attempts to start the engine, and it may fire for a portion of a turn. The engine then hydro-locks because liquid gas cannot compress and you break a piston or a rod. It is rare, but it does happen, and it's usually expensive.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
