Old 07-22-2015, 04:45 AM
blykins blykins is offline
Can do a complete engine, from pan to fuel line for $9999. This will use the factory block, crank, Scat rods, Racetec pistons with a modern Mahle ring pack, factory heads with SI valves and our valve job, a Blue Thunder intake, Ford Racing valve covers, pulleys, brackets, alternator, Holley 650 carb, custom Comp Cams solid flat tappet cam, etc.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
