Old 07-26-2015, 02:50 PM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Originally Posted by DaveW View Post
Except, i forgot you probably have DBW on that beast, so forget everything i said unless you are converting to cable.... whoops
You beat me too it Dave.
Guy there are a few aftermarket Cruise control kits for DBW throttle - I'll email you some links as when I was looking for mine I kept on coming across good DBW versions rather than cable ones. (I ended up using the stock LS1 Cruise control module which works a treat)
FWIW - I have a single speed shrouded FAN running off the HS FAN output etc (with modified temp turn on etc) and it works a dream. Driven in Melb traffic on a a hot day and all good. The only overheating thing in the car was the driver :-)
I reckon a single HS FAN output fan/relay etc is simple and effective using the KISS principle :-)
gregg
