Old 07-27-2015, 06:00 PM
jwd's Avatar
jwd jwd is offline
Originally Posted by colubra View Post
Did speak to previous owner and while he did not recall the exact cfm(might be 600), he said the mechanical secondaries had been disconnected. What issues and concerns would this bring about. Thanks to all as I am learning a lot. Will be able to get pics this weekend.
Sounds like they are trying to make a terrible set up work. They disconnected them because the engine would bog and die when you stomped on it. A 302 at 100% volumetric efficiency (not usually possible with a street engine)will only flow 567 CFM at 6500 RPM. Even an unstreetable, full out, ballz to the wallz, purpose built race 302 can't flow more than 800 CFM at 7500 RPM.
If you want this car, plan on either getting two correct carbs. or better yet, a single carb. and manifold. What's on there now is garbage.
