Old 07-28-2015, 03:30 AM
Tommy's Avatar
Tommy Tommy is offline
I'm not sure I fully understood your description, but if one bulb is weak and another that shouldn't be lit is also on, I suspect you have a bad ground. Run a temporary ground wire from a known good ground to the faulty fixture. If that fixes the problem, you have confirmed a bad ground. Then you need to find/fix/bypass the bad ground.
Tommy
Previously owned EM Cobra
