Old 07-30-2015, 09:03 AM
Xack's Avatar
Xack Xack is offline
Cobra Make, Engine: West Coast Dreams
The water neck, probably the highest point should be a good place to mount a bleed valve. This will cure your air pocket problem once and for all. You just need to run the engine and open the valve until you don't get air. Re check it occasionally.
