Old 08-01-2015, 07:30 AM
Mr Jody Mr Jody is offline
Default Valve Cover Spacers
To give you plenty of added height (1-3/8”) without modifying the VCs, these spacers are an option. A bit pricier than just modifying existing covers, and an extra set of gaskets is required, but you will be assured of having enough space, and leaves the VCs untouched should you decide to change later and want to sell them without being modified. But, make sure the added height won't cause interference problems elsewhere. Available at many places, here is just an example.
Ansen 7667 SB Ford Aluminum 1 375 Valve Cover Spacers Polished | eBay
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
