Old 08-10-2015, 02:47 AM
xb-60's Avatar
xb-60 xb-60 is offline
Default Need advice on where to source flywheel and clutch
Need advice on flywheel, clutch (pressure and friction plates) and hydraulic TOB ...which ones, and supplier?
Hard points are:
1. Ford SBF 302, 50 oz imbalance
2. Quicktime RM-6063 scattershield (depth 6.3”)
3. Toploader gearbox (10 spline, 1-1/16” dia input shaft)
Flywheel needs to be a 157 tooth, weight 22 lb to 24 lb
Clutch needs to be a 10.5” dia max
HTOB – I know nothing, nothing! (thanks Schultz )
Bits would need to be available in Australia, otherwise freight for these heavy items from OS would cost an arm and a leg....
I've seen a big range of prices, hence any advice is greatly appreciated.
Glen
