  #21 (permalink)
Old 08-13-2015, 03:32 PM
xb-60's Avatar
xb-60 xb-60 is offline
Originally Posted by davids2toys View Post
My car also has an aluminum flywheel (don't know what kind).
I would agree with Patrick about this. The car is so light, and with an FE with lots of Torque, you don't need the inertia of the heavier steel flywheel. Car revs up very quickly like a freewheeling built small-block!
So my only complaint would be is that it does not hold the RPMs in between shifts because it is so light and there is no inertia. My first Cobra had a steel flywheel and my grandmother could have driven that car!!! Mine is a little more of a challenge to stay into the gas a bit more to get a clean smooth shift. That situation gets worse the hairier your cam is because it is very easy to fall out of the power range!
My engine is an SBF (car is an FIA replica) not an FE. I'm still not convinced that lighter is better in a flywheel. Of my two other cars, one has what feels like a heavier flywheel, and the other has what feels like a light flywheel. The heavier setup is the easier of the two to drive in a 'sporting' manner. So if you blip the throttle and the revs rise and fall more quickly with a light flywheel, where does that get you on the road? Track work with the revs always up near the top end would be different and would probably suit a light flywheel if the rest of your rotating mass is light as well
Back to you Phil
Glen
