Old 04-29-2002, 09:59 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Lightbulb Cosmoline is available in aerosol cans!
You can just spray it on the motor parts you want to protect, and fill the inside of the motor with oil as much as possible. To clean off, use a soft brush, and lacquer thinner or a good degreaser.
THEN, you MUST use several thicknesses of plastic bags, sealed with quality packing tape,....the clear food grade type of bag, AND include several LARGE packs of dessicants inside. Hydrosorbent is the best dessicant (I sell it on line) Looks like you need about 6 of the 40 gram Hydrosorbent units (reusable, have moisture indicators, it turns pink to indicate the dessicant is full,..this is why you want to use a clear bag, so you can monitor this)
You also must store the item in a heated environment. Cold makes rust, due to condensation.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
