Can't imagine why the clearbra won't work, any experienced application guy can use it from a bulk piece with a simple pattern.
The 2nd choice would be the newer spray application product which is a straight forward DIY deal and you can multi coat it for the protection level you're comfortable with and removable if you screw it up.
The stuff you used " may" use a solvent that can attack the clear, repeat, " may".
The older I get, the faster I was.
