Old 08-18-2015, 04:17 PM
DAVID GAGNARD's Avatar
Originally Posted by Detroit Bill View Post
I am not sure that is completely true. A stroked 427/482 FE may not idle well but it will pull hard off idle. In a Cobra the tires will be spinning in any event. The HP/TQ is not peaky it is linear. I realize the OP has a Windsor but since he is gathering information that should be pointed out. A 585 HP 427/482 is very different than a 585 hp 351/427.
Good luck!
Bill:
I agree with you 100%,I was referring to a small block stroker making 585 hp.....A big block stroker making the same hp will be a lot "tamer" and streetable engine than the 427 small block stroker.......
David
DAVID GAGNARD
