Old 08-18-2015, 05:30 PM
patrickt patrickt is offline
Originally Posted by Large Arbor View Post
Actually, I woud like to convert the ammeter gauge to a voltmeter gauge. What would I connect to register voltage? Battery?
Phil
A volt meter is the easiest gauge in the world to hook up. You can run it off of virtually any hot lead that is under the dash, or off the ignition switch post, or the battery, or the master circuit breaker on the firewall over by the starter solenoid -- any of those, or the cigar lighter feed, the fuse box, etc. Super easy. Bypassing the ammeter is just slightly more difficult, but not much.
