Old 08-21-2015, 05:25 AM
Barry_R Barry_R is offline
Detonation itself won't line the ring gaps up.
But if you are running in detonation you will deform the piston - which will pinch the second ring as the land (the name for the upper and lower groove surfaces) folds up, locking it in place.
The damaged second ring segment will eventually cause the top ring land to deform and repeat the failure in a different fashion - by giving the upper ring's gap a place to "catch" in the dent - hence the line up.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
