08-23-2015, 06:16 AM
Cobra Make, Engine: SPF#0760
If both your brake lights don't work, I would look for the activation switch that is related to the brake pedal. Could be a simple button switch located on or near the brake pedal that is activated when you depress the brake or an in line pressure switch with two wires. Of course you should test the bulbs first and also the ground to the bulb sockets.
SPFWiringDiagrams@Comcast.net
