Old 08-23-2015, 03:17 PM
DAVID GAGNARD's Avatar
The work on the car and tune from Oltoffs reflect the current condition of the car as all that took place in 2009. When the previous owner bought it he had it sent to Dennis to work through the car and get it right. According to the previous owner, records and local cobra guys...nothing on the car has been changed since it left Dennis.
If everything is supposed to be the same as when Olthoff tuned and did the chassis dyno, then something has happened to the engine since 2009 that has made it "lose" about 100hp........ I don't think the compression numbers are it and with only 11,000 or so miles on it,it shouldn't be worn out and due for a rebuild........
You need to verify the cam/stroke and a few other things to see exactly what you have....
David
DAVID GAGNARD
