Old 08-23-2015, 04:48 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
Originally Posted by DAVID GAGNARD View Post
If everything is supposed to be the same as when Olthoff tuned and did the chassis dyno, then something has happened to the engine since 2009 that has made it "lose" about 100hp........ I don't think the compression numbers are it and with only 11,000 or so miles on it,it shouldn't be worn out and due for a rebuild........
You need to verify the cam/stroke and a few other things to see exactly what you have....
David
David, I don't disagree. Previous post was just explaining the timeline and where the Oltoff work for in. We will definitely be verifying as we go through it
