Old 08-24-2015, 10:51 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
They are one in the same. That ERA furnished master circuit breaker that is on the firewall right next to the starter solenoid is rated at 50 amps.
Now here's another option that you might want to consider. You can replace that ERA furnished 50 amp "auto reset" circuit breaker with one that requires manually resetting. A little button pops out of it when it throws and you have to manually push the button back in -- just like the circuit breakers in your house.
Pretty cool item.
This is what I found. They all have plastic mounts. Don't these circuit breakers need to be grounded like the metal mount type 1 auto reset presently on the car?
Manual Reset Circuit Breakers - with Bracket
http://www.ebay.com/itm/171596826353
http://www.wiringproducts.com/50-amp...gle-mount.html
I will still hook up the MSD POS wire with a fusible link as Rick suggested and you agreed. In addition, change out the ERA 50 amp CB with the manual setting type
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
