Old 08-25-2015, 03:21 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
If your only producing about 530HP from a 427 you have not experienced the full satisfying power of a well build 427. Something is very mismatched. Get the right parts and tune and if you get the true 585 you not only will pull from 2000rpms, it will scare you at 6500rpms in a 2500 lb. car.
I have a 351 with the right parts all sourced out to matched and I'm at 490FWHP or 1.4HP/CI. I can pull from 2000 rpms. to 6400rpms. 1.4HP/CI in a 427 is 597HP. Get your Carb, Intake, Heads, valvetrain,cam, and exhaust to match and you won't be disapointed, trust me.
I have great street manners also and you will too, and good gas mileage in the highway.
The easy way out is power adders. Like what was already said they work also, but you said you want the lumpy radical sound of a windsor, my advice will give you all of that
Lou
