Old 08-25-2015, 07:25 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Originally Posted by xb-60 View Post
Good point Mike (and Berninca).
For starters, the clutch and flywheel I settle on will be branded the same and from the same supplier; that seems a no-brainer. Balancing the two together should be easy and relatively cheap.
Glen
A yup there and well worth the peace of mind. You can use a different fly but balance everything before crawling under there and putting it all back in! IMHO.
