Old 08-26-2015, 10:08 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
252/262 @ .050"?
If that's duration at .050", that's a very large camshaft for a 427. My engines that are around this displacement and use hydraulic rollers have about 12-14 degrees less duration and peak at around 6000-6200.
My guess is that the cam has been changed sometime in the car's life and that cam does not match the rest of the engine/car/goals. Your compression test shows low because the cam is so large and the numbers actually jive for a cam that large.
I'm thinking that if these are .050" duration numbers, the cam is so big that you have no bottom end and you can't run high enough in the rpm range where the cam wants to be efficient.
If those numbers are advertised duration numbers, then that would be a tow truck cam....
I'd change the cam....
Following up on this. Per the Comp Cam Slip that is part of the motor build sheet the info below is listed. If this information makes since to you it makes you wonder why a camshaft such as this was used.
*Gross Valve Lift .576 Intake / .576 Exhaust
*Duration at .006 Valve Lift 314 Intake / 329 Exhaust
*At 112 Intake Center Line / Duration at .050 252 Intake / 262 Exhaust
