Old 08-31-2015, 01:09 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Is your car using the two electric pumps in the trunk on the passengers side? If so are the pumps the "Facet" cylinder style? If so there are filters inside the bottom of each pump, if you are running a mechanical pump the filter may be between the pump and the carb.
