Old 09-01-2015, 06:37 PM
Pman1961 Pman1961 is offline
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Follow RT's instructions and all will be good. If the stud does not fit snug in the spindle you will need to order RT's reamer tool as I had to do. The original ball joints are junk!! They were real difficult to move the stud side to side or turn. The new joints spins with the tip of your fingers!! My results were that I did notice less effort turning with my Yokohama Avids. When I changed to Avon's tires because of the soft tread compound turning required a little more effort or as it was before I changed the joints with the Yoko tires. Very pleased with the joints!!
