Old 09-02-2015, 04:09 AM
Default Find the oil modes for FE motors
hushersnake The block is .020" over on bore. Should be safe.
AS for the oiling system. There is a 5 page article on improving the oiling system for all FE blocks. The most important is to enlarge the supply between the oil pump up to the front of the block and check the main oil supply going down the side of the block. The side gallery gets smaller the farther to the back of the block it goes. Some guys match the front to the back where the release valve for oil pressure is. Don't hit this with a drill bit. It's the same with matching up the main bearings and supply holes. Some guys ablong the holes to match. other say its to control the oil and help get more to the back of the block. Super Ford Mag that had the article has a picture of Bob Gliddens car on the front cover. Want to say the mag was done in 1988. Oiling system for cooler and lines, IF you are going orginal look, #10 lines are OK. IF you are looking to play hard, take the system to #12 lines. Oil pan, If you go with a windage tray, either stock one or Canton one drill holes in the bottom, about 8-10 hole in the center to help the oil return faster to the oil pan. Some guys add scrappers to help get the oil off the crank and back to the pan. Gaskets, Make sure that all the holes line up. Head gasket, one goes on backwards. Check the oiling hole for the heads. If installed wrong, no oil to head and rockers. Same for studs in heads, 1 is smaller to allow supply to rockers and springs, I use double valve cover cork gaskets. I glue them togeather. I flood my heads with oil. This helps cool the valve springs. The pos valve stem seal you will get no oil being sucked into the valves and ports. (Blue Startups). Smooth and blend all opening for oil supply.
Last note, intake manifold grind out the ports to match for coolant. Make sure that the machine work matches on the angles of the heads to the block, the intake to the heads. If the block was trued The center of it needs to be trimmed down also. Some guys have had .010" for surface cut and the intake will not seal. GUys are using studs for extra strenght to pervent leaks.
HYdro Roller camshaft, Crane used to make a .587-.607" hydro. It makes a ton of torque. Motor has a little lope and is easy on the valve train. I forgot if I retarded it or advanced it for more torque and less HP. All FE camshafts seam to come with a 4 degree offset built in. Need to dial in the camshaft. IT smokes the tires in 2 gears. The anti pumpup lifters crane used to sell are good for 6,500 rpm. The system floats at about 5,700-5,800 rpms. ONce you fill these lifters with oil they will not drain down. YOu have to pull them out and take apart to remove oil and reassembly. You get 1 shot at setup of rockers. You will need custom pushrods for this. Get the pushrod length kit to help with keeping the rocker on the center on the valve stem. I cheat to get another 400 rpms out of my motor without the major power drop off from hydro lifters. MY motor is aluminum and expands more that iron motors. I have the lifter plunger perloaded at .015". When motor is hot, makes a little noise but there is no major power fall off in the high rpms. I have an MSD 6AL with a 6,200 rpm chip. My motor is out of power here anyway and I am not wasting the motor with more abuse than needed. I have just under .100" between valve and piston clearance. Another check out thing.
Last rockers, not sure what you are going with, IF you can find a set of ERsons, buy them. Make sure you use studs for the shafts and get heavy duty ones. I started with a Dove setup and cracked 2 rockers and 1 shaft. get roller rockers for both tip and main pivot. Sorry for long info. Google should get you the oiling modes, if not send me an address, I will mail you a copy of them to look at. Last note, The oil pressure reading on the gauge IS NOT what the back of the motor is getting. A side oiler is better than a center oiler motor. You lose about 10-20 psi of pressure front to rear. Don't idle the motor for long is possible. PSS How about a first name, Sorry Husker and Snake don't work unless you are a farmer, Then you get the Massey-Ferg, John Deere, Case, I think you get where this is going. Rick L.
