Thread: Fender Rubbing
Old 09-02-2015, 04:13 PM
Default you are giving more info
jrbruc84 Is it Bruce? If this is only over bumps, replace the shocks, but I don't think this will fix a body hitting problem. It's a tire rub. Put 1 thin spacer in the r/s of 1/8" I think that will clear the tire. The other thing is we don't know what the rear camber reading are? You might only need to add shims to the r/s drive shaft to help clear the body. Was the rearend apart? They might have not reinstalled all the shims and this will cause the same problem. Call me in the about 3 hours. Rick L.
