Old 09-02-2015, 07:53 PM
cycleguy55's Avatar
Originally Posted by krausewich View Post
Have you looked into an HID upgrade to run Xenon bulbs?
They come in different intensities which have different hues
to the light they produce, but there are some excellent white
range options. Maybe compare the light patterns between your
LED/HID options to see which will give you the brightest results.
Good luck,
Mike.
Thinking of converting to HID?
"So you've read about HID headlamps and have it in mind to convert your car. A few mouse clicks on the web, and you've found a couple of outfits offering to sell you a "conversion" that will fit any car with a given type of halogen bulb. STOP! Put away that credit card. HID headlamps are terrific, and they can offer significant and substantial safety performance advantages over halogen headlamps, but only if they're designed and built as HID headlamps from the start. Installing an "HID kit" in a halogen headlamp isn't an upgrade, it's a large and serious safety downgrade."
Read more at: Daniel Stern Lighting Consultancy and Supply
Brian
