Thread: Bad Starter
Old 09-05-2015, 11:10 AM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
It's not a strap. It's a skinny little black wire. There is no frame to engine ground strap, and if you put an inductive ammeter around this skinny little black wire you'll find a good bit of the current for loads that are grounded to the frame are actually passing through this guy.
Patrick,
Concerning this wire. I read somewhere else in the from that you installed another ground wire from the manifold to this same location as the black wire. Was that in addition to the black wire or instead?
As far as doing this test, was that with the car running and progressively turning on all the accessories one by one and you watch your amperage grow the more you turned on.
OK,. so I only have a multi-meter, no inductive ammeter. Can I just break the connection and run it thru the multimeter to get the reading?
Thanks...Dave
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
