Old 09-06-2015, 03:07 AM
Modena's Avatar
Modena Modena is offline
Well it was certainly a good day today, happy Father's Day!
First I put in 5 litres of fuel, but she wouldn't fire and fuel pressure was zero. A bit of head scratching and thinking that the fuel pressure sender was b0rk3d and something else must also be wrong, but then I thought of the baffle. The baffle in the fuel tank is obviously pretty closed, and never having had fuel in it, it was totally empty. I dumped another 18 litres in, and voila off we went to the races. Another Sideshow ECU and loom fires on the first go.
No leaks which is a good thing!
The only issue I can find is that my oil temp gauge doesn't seem to be getting a reading, it never moved off "LO" and is supposed to read 32-160C, so I need to look at that.
Just uploading driving videos now......
oh yeah....not much chance of getting through full reg with these sidepipes
my high-pressure pump is L-O-U-D. It makes an 044 look quiet. I have a lift and HP pump, both are from Fuelab.
Ben in AU
