Old 09-07-2015, 12:26 AM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
The car will not be running if: 1) the MSD box shorts out (which will blow the internal 15 amp fuse on the MSD circuit board) or 2) the feed wire to the MSD box shorts out (because the box itself will no longer be fed. If the MSD feed wire shorts out, or if the line that leads to the ammeter shorts out, the circuit breaker will blow because the battery will try and pump lots of amps through that line even if the alternator is still turning. The glass fuses protect shorts on the load side, for the most part. Remember, almost all of the wires in your car, even the skinny little wires, will handle 50 amps for a short while <pun>. and the CB will blow if the battery dumps more than that. One of the most common wiring fires is the result of a short in the line between the alternator and the battery (the one with the ammeter in between). If this line shorts out, the CB will blow, but the alternator will still pump out its maximum for a while, and that's where the fire comes from. Now, my alternator only puts out 60 amps, so the location of the fault will spark and smoke, and maybe some plastic nearby might catch, but the wire itself can carry 60 amps with no trouble. Some of the bigger alternators are a different story.
Thanks Pat. I think I actually understand what you are saying here!!
Is there a way to tell how big of an Alt you have? I know I have an external regulator and that is about it.
Dave
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
