Old 09-08-2015, 06:40 AM
Modena's Avatar
Modena Modena is offline
Originally Posted by Gav View Post
That system ended about 6 months ago Ben.
A Cobra or any replica going into club reg' needs to be engineered and a roadworthy certificate.
The same goes for modified production cars, for example a V8 powered LJ Torana, however an engineered replica will still have 'H' plates where as a modified production car will have 'M' plates.
The "old" way was simply a club safety sign-off. The new way is the club safety sign-off AND a roadworthy. There is no engineering required.
You may be referring to this extract from the below;
https://www.vicroads.vic.gov.au/regi...1-january-2015
  • New modification guidelines specified in the Guidelines for modifications to vehicles operated under Victoria’s Club Permit – Vehicle Standards Information No. 33 (VSI33) [PDF 296 kb] apply.
  • If an initial club permit application is submitted for a vehicle that is modified outside of the appropriate modification guidelines, a Vehicle Assessment Signatory Scheme (VASS) approval certificate covering the modifications must be provided with the permit application.
So yes if your vehicle is modified outside the guidelines, you will need engineering (VASS). A "typical" Cobra replica is not considered modified. It is a replica of a 1965 427 SC Cobra. It has 4 wheel disc brakes, a V8, a roadster style with replicated body, and all the other things that (fairly) accurately replicate a 1965 Cobra. The scheme does not consider a Cobra (the Cobras typical of yours and mine) to be modified in this sense. If you were to make your Cobra 4WD, rear-engined or some other madness then it would be seen as modified from what an original Cobra was and would need engineering.
Under CPS this is not an ICV, it is a replica of a Cobra and the CPS considers it a Cobra.
That is my understanding anyway!
Ben in AU
