Old 09-08-2015, 09:44 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Yes, with the engine off and everything turned on that would give an exact reading on the total amperage. It was just easier to add it all up in my head than to walk downstairs to the garage and actually measure it. Since all my lights are LEDs, which account for very little current, my fans and head lights are pretty much it. Of more interest is the amp draw by the fans. If you look at your SPAL data sheet, it has a nice little table that shows the different current draws based on the temperature and whether you have it as a pusher or puller. When I shut down my engine, and it is nice and hot, the current draw, as measured, is five amps or so more than when the engine is cool. Of course, the voltage is a little lower too since the alternator is not running.
I borrowed a friend's amp tool See post #45 Bad Starter
Car OFF and cold, with the fan, high beams, and wipers on I got about 15 amps going thru the CB. Seems pretty good to me?
No brake lights, horn or blinkers.
I might have to do this again. It is after midnight and I'm beat. Maybe I screwed this up...LOL
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
