Old 09-11-2015, 11:29 AM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Think you are correct about upper control arm movement--the Mii's were known for the UCA nuts losing their grip. The serrations on the flange of the nut wear out. Should be easy to check as it probably scraped the mount pretty bad. If not, just compare to other side; they should be about the same as far as location from alignment. Brakes would usually only be a problem when braking unless a caliper locked up by circumstance.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
