Old 09-12-2015, 10:43 AM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
You can't measure amps that way. In fact, you can't measure resistance that way either. So, put that completely out of your mind. With the circuit breaker connected, and some electrical loads running (like lights and fans) your inductive ammeter will tell you the current that is running through that circuit, but a voltage drop test will tell you if that circuit breaker, or a connection, or a wire, is creating a bottleneck -- and that's what you really want to know.
AYIYIYI
So what is the purpose for the ohms function on the multi-meter if it is useless. I did a quick Google search on voltage drop test and in what I do understand, it makes sense!
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
