Old 09-13-2015, 08:54 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Photo is too dark for me to see inside the nose but my vote for the culprit would be the pipe to AN fittings. Largely dependent on the mating surface angle of the male and female sides of the coupling. If one of them is a "bit off" they won't seal properly. The other area of possible problem is cross threading when assembling or debris around the shoulder of the female ferule.
DonC
