Old 09-14-2015, 03:09 AM
Towmaster's Avatar
Towmaster Towmaster is offline
I just use -8 fittings & hose everywhere in my fuel system. Carter lift pump & 044 but mine (Ford) only uses 42 psi max.
The Supercar runs twin Holley red lift pumps (one from each side of the tank) all -8 into the 5 liter surge tank then through an 044 (two actually, one main & one reserve , only one runs at a time) then through the -10 lines to the engine then splits to two x -8 feed to the fuel rails...
I'm guessing -6 should supply enough fuel really for what you want.
