Old 09-15-2015, 02:58 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
I wrapped the fuel and brake line in DEI heat sheath with velcro and installed the floor and tunnel shield on the underside of the floor pan just like the passenger side.
Mufflers wrapped. I can't believe how big of a difference this product makes. If you measure and cut carefully, one kit will do both mufflers.
The heat shield to protect the master cylinders fit correctly, so I installed it with some of the DEI heat shield on the side facing the pipe...tight squeeze!
