Old 09-15-2015, 08:48 PM
autobody prof. autobody prof. is offline
Cobra Make, Engine: Pacific Roadster, 427 stroker, TKO 500
It all depends. What color are the stripes? What color is below the stripe? What brand of paint are you using? What is the reduction ratio i.e. 2-1, 3-1, 4-1? If you are going with the traditional white stripe and you are going to paint over black then you will need a little more material. If you are using a quality brand base coat such as DuPont, PPG, BASF Sikkens, Glasurit etc you will have excellent coverage. A ratio of 2-1 means 2 parts color and 1 part reducer as an example. Quality brands have much more pigment and cover quickly. Lesser brands will require more material as they do not have the pigment. So if you are going with a quality brand base coat a pint will be more than enough. Anything else I would think about a quart of material.
