Thread: Misconceptions
Old 09-17-2015, 01:47 AM
Ron61's Avatar
Ron61 Ron61 is offline
I agree with you 100%. The things that I don't have the room or equipment or actual experience to do I have done by people that know what they are doing and how to do it. I had my Coupe completely gone through by a very knowledgeable and good mechanic and it was then tuned by Robello Racing. I can do most of the regular things but when it came to the tuning and some of the more complicated things I wanted it done correctly as I raced it some and drive it hard. I did get scales and had it corner balanced as well. The few people that we still have around here who have these cars do much the same as I do.
QUOTE=cycleguy55;1362977]Regardless of the quality of the kit or roller, I'm more concerned about the folks who build, modify or maintain these cars who don't seem to know the difference between a pipe wrench and a torque wrench. In the 15 months since purchasing my car I've torn apart and re-built a lot of stuff that just made me shake my head, including:
  • 1/2 of rear main seal installed backwards
  • gas tank rollover valve installed backwards
  • valve lash set as if the lifters were solid - and they're hydraulic
  • gas tank not properly vented
  • emergency flash wire cut under the dash
  • brake lights didn't work unless ignition was on
  • shifter lever making solid contact with tunnel opening so it wouldn't fully engage 5th gear
  • one muffler insert was installed with louvers facing forward, the other facing backward
  • etc.
Yikes. All fixed now.[/quote]
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
