Old 09-17-2015, 04:53 AM
SydneyChris SydneyChris is offline
Had a decent day with sorting the electrical issues created by the overwhelming ignorance, incompetence and complete apathy of a northern Sydney Kobra builder.. not only was there a number of wiring faults, that he specifically introduced into a clean harness, the ancillaries were incorrect for the motor type, the tune provided was from a mafless 6L motor (L98), rather than an LS3 with a MAF as the factory runs, the majority of the fault codes were being generated because one of the plugs for the ECU was wired and then installed backwards.. !
Yes .. it is staggering.. well its staggering if you knew how everything he touched he did a half baked, inaccurate, incomplete and totally flawed job on everything he touched.
Fingers crossed this is the last in a fairly comprehensive list of stuff up he created.
Looking forward to getting the fuel pumps rewired to a higher ampere breaker tomorrow and see if it will hold fuel pressure and run.
Chris
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
