Thread: Bad Starter
  #37 (permalink)
Old 09-18-2015, 12:15 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
I did just that and sent pics as well. I suspect the starter was moving around as initially it worked fine. Over time it loosened and that created the problems. I will sleve the larger starter casing bolt holes and take up the slack, eliminating the possible movement. COuld not get a ring gear within 24 hours so I will stick a new flywheel on as well. Hopefully will put it all back together tomorrow.
phil
