Old 09-19-2015, 10:57 AM
CHP2RA CHP2RA is offline
Cobra Make, Engine: Superformance MK III Roadster, Roush 402
I've put a multimeter in the trunk, to check the voltage at the battery Cable the next time this happens. if I understand correctly I should put the positive multimeter lead on the battery cable, and the negative lead to a ground somewhere, not on the negative battery cable.
I've put jumper cables in the trunk as well: next time this happens I'll attach one to the negative post and cable on the battery, and run the other end to touch the starter case.
Thank you both for your suggestions.
